THE TELEPHONE DOESN'T RING. ICON SHOWS RINGER TURNED OFF AND WILL NOT ACCEPT NEW CALLS
SOURCE: Handset locked on Binatone lifestyle signature telephone
Hold down the asterisk key, not the hash key.
SOURCE: Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume Adjusting the Ringer Volume You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base. With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off. When you hear the ringer volume level you want to use, stop pressing keys. The handset or base will use the new ringer volume starting with the next incoming call. Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings. Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
SOURCE: No ring on incoming calls
I found this in statement in a review of Magicjack on Amazon, hope it helps.
The one problem I did encounter was at the beginning when I found that
one of my phones wouldn't ring when someone called me. By googling the
problem, I found out that this problem is due to the ringer equivalency
number (REN) of the phone you are using (google "phone REN" to find out
what it is). Most phones have their REN listed at the bottom of the base
unit. From my experience, I believe Magicjack will only work for phones
that have REN of up to 1.0B (add up all phones in your system to get
your total REN. Mine had a corded base with 0.6B REN with 2 more
cordless handsets. I figured that made my phone system total to 1.8B
REN). Magicjack did ring on a phone that had 0.98B REN. To fix the
problem, I bought a multi-handset GE DECT 6.0 (model 28223 Series) which
basically has REN 0.0B. Magicjack had no problems ringing with this
phone. My phone system was over 3 years old anyway so I didn't mind
replacing it.
SOURCE: Can't get phone to ring
No problem, just push the volume up key untill the ringer is at the level you want it.
SOURCE: Ringer does not ring on one phone
Well it depends on the model, Most of them you can adjust the ringer volume by pressing the volume up key while the handset is onhook (not in use)
Ring volume
The handset ringer volume can be adjusted from five levels.
• Press MENU/SELECT to display menu when in idle mode.
• Press up arrow or down arrow to reach Setup HS. Press MENU/SELECT.
• Press up arrow or down arrow to reach Ring volume . Press MENU/SELECT.
• Press up arrow or down arrow to scroll through the choices and a sample of each ring
volume will be played. Press MENU/SELECT to confirm.
• The screen displays Stored and you'll hear a confirmation beep.
You can adjust the ringer volume by pressing VO L+/VOL- on the
telephone base when the telephone is ringing.
