Hello my dishwasher just makes a noise when switched on what could it be please sounds like a water problem?
thank you
Normally the inlet pipes have a stailess steel mesh to block the dirt from entering your machine, when you tap water and it reached its level then the solinoide is actully closing the water for you, it is posable that that mesh is blocked and the solinoid is making that noise. Close the water supply, remove the pipes on the machine and make sure that mesh is not blocked, if it is open have a look at the fan belt, that can also lead to the noisy problem, if it is not a direct drive
