I purchased it from someone who had not used it for several months.
SOURCE: Have Nikon F3. Did
well first off pheonix, is the motordrive still working, hopefully it is. if so then the only concern you may be encountering right now are the contacts for your Varta V76PX / 357's. few months of no operation may give enough moisture inside the camera and rust will start to form, it may not be visible on the outside of the battery contact but it could be inside. battery contact repair/replacement may not cause too much, so thats a good side.
if this is the problem (my boss had an D50 and stroed it without silica gel), the next time you store it, use a silica gel, or put one in the box/bag where it will be intalled. just a personal thought
good luck
SOURCE: Battery charging problems
Ther may also be a fault with the camera body. Seek advise for a Nikon repair centre.
SOURCE: its only 1 month that
Hi,the battery may have a dead one.,since you have a valid warranty pls ask for a replacement..
It is normal for the batteries since they have been fully tested under load..
sometimes it happens even with a famous camera maker as NIKON but remember batteries manufactured by another source,they just put a brand name whoever asks.
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
It doesn't even power up. There is not error message--no lights come on.
