Hi ! for drive belt, please visit the website below. If you need more information about a specific electrical issue you can reach me at [email protected].http://www.motorpartstore.com.Good luck and have a nice day
SOURCE: I need to know how to replace a 2001 soft tail
yes buddy swing arm removed belt put behind swing n arm and the wheel losened and slide the wheel forward dont force the belt and after 100miles check the belt tension if so adjust it and also you will require a torque wrench to torque the bolts on swing n arm and on rear wheel the wheel is 100 NM and swing n arm is 79 NM bud
Testimonial: "Thanks for the info. Does only one side of the swingarm has to be loosen or both sides?"
SOURCE: what is the procedure for replacing the final
To replace the final drive belt on your RK is not a small job. You must first take off the foot board on the left side of the bike. drain and remove the outer primary cover, take loose and remove the engine sprocket, primary chain, and clutch assembly, remove the exhaust system, remove the starter, remove the inner primary cover, take the rear wheel out from under the bike, and take the swing arm off.
So, as you can see, it's not a small job by any means. That's why it cost so much to have the dealer do this.
Let me know what else you need to know.
Ride Safe
Steve
Testimonial: "thanks for the info, I knew it would be a big job but needed to know just what all was involved"
