Engine management light flashes wont start if light stays on it fires up runs ok , turn it off then retry light starts flashing wont start again immobiliser activated when light flashes.
SOURCE: Flashing immobiliser light
my engine will not start the the immobilizer light is flashing the key does not have a chip in it but the owners manual said the kay has a code but the car startit before with the same kay my car is hyundai accent x reg year 2001
SOURCE: renault kangoo 1.9 d immobiliser probims.{2001} model.
hold the central locking button down on the centre consul inside the van for more than 5 seconds the doors should lock Then unlock,then press the key fob within ten seconds the doors will lock and unlock again this will re- program the key code
good luck jk
SOURCE: Fiesta Diesel (Y Reg) intermittent starting(flashing immobiliser)
diesel ,,,just bypass the immobiliser ,20mins work
SOURCE: flashing temp light
The clicking sound is usually
associated with a dead or low battery where there isn't enough power
for the starter to crank so it clicks. Test the battery as it
should read 12V plus/minus .2V
If the battery is good, then the starter solenoid, starter cables or the starter motor itself could be a problem.
