Sennheiser HDR-45 Consumer Headphones Logo
Anonymous Posted on Dec 24, 2008
Bad battery for my Sennheiser HDR 45 headphone
I want to purchase a new battery for my Sennheiser HDR 45 headphone set. My cell phone number is 515-868-1514, and my name is Gary
  • 2 more comments
  • joseereis Mar 29, 2009
    I have the same problem with the HDR 45, not holding charge. My batteries used to hold charge for a entire evening. Recently, they only last an hour. I purchased new ones on Amazon.com for $18.00 each.
  • Anonymous Mar 17, 2014
    I have Sennheiser HDR 120 headphones. After 2 minutes, the On/Off light goes out and I have loud static in my ears. I can take the plug out from the tv, the On/Off light turns on again and then I listen for another 2 minutes until the same occurrence takes place. Please help!
  • Anonymous Mar 28, 2014
    I bought a new set Of Sennheiser RS110 last month, and wanted to pick up an older supplimental heradphone without a transmitter.
  • Anonymous Mar 29, 2014
    suddenly lost sound from both headphones
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jan 15, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
5473
Points
26
A replacement battery can be purchased from Sennheiser for $20.00.
Battery is: BA 151
Sennheiser Link:
http://www.sennheiserusa.com/newsite/productdetail.asp?transid=004146
Sennheiser HDR 130 with TR 130 transmitter not working.
If you twist the earpiece,one of them has two NIMH AAA batteries ,worth checking out if these are gone ,which is what happened to me.I was about to bin my rs130's and just stuck two new rechargeables and the earphones are working again!!!!!
As for $20 dollars from sennheiser for replacements!?!?!?
You should pick up two NIMH batteries for a couple of bucks on ebay or amazon.DO NOT USE ORDINARY BATTERIES!!!!!
Sennheiser hdr 160 will not pick up the signal from the receiver
assuming the battery is charged, have you tried to switch to a different frequency band, etc.?
check page 28 of the user manual for possible actions when there is no sound in the headphone.
3helpful
How can I get a manual for HDR 45 ?
You can download the manual for the product from the below link:
http://www.wireless-headphones.net/rs-45_manual.pdf
Hope that allows you to resolve the issue. Please revert back for any further assistance.
Regards
Anand
My cordless HDR 130 Sennheiser headphones no longer charge. I have only had them for about four years. What do you think is going on?
The batteries are at end-of-life OR your charger has failed.
Forst replace the batteries... they are MOST likely bad. Charge the new ones before using.
15helpful
Sennheiser hdr 120 headphones no longer hold a charge. where are the batteries in the headset?
Twist the pad counterclockwise on the left earpice. You'll find the batteries underneath.
2helpful
2answers
My sennheiser 120 headphones are wearing out. After much use.
You can buy the HDR 120 model which is basically the headphones lone
These will work with the base in conjunction with the set you have now.. or as a replacement
You can also buy replaceable ear cups for less than 20 dollars (check the Sennheiser website)
Finally you may want to replace the rechargeable batteries in the headphones you have
Just make sure you replace them with the exact type.. I believe those are NiMh AAA
Pop them out and go to any Battery Plus or Radio Shack.. a new set probably run you less than 7 bucks
My point.. for less than 30 dollars you can have your old headphones working and looking like new ones
Give the new batteries an overnight charge before using them
Good luck
2helpful
Bad battery
Battery Part Number: BA 151
Sennheiser Link:
3helpful
Sennheiser RS 130 Wireless Surround Sound Headphones
Did you try to remove the batteries and at the same time unplug the power of the base for 30 sec ?
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
