I can't change any of the settings on it, and the little child lock light is on! Does it think a child has crawled in there and it doesn't want to kill it?
In the owners manual there is directions on how to unlock it, sometimes as simple as just holding down the child lock button for a period of time
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: My dle2514W LG electric dryer is displaying a CL
My dryer had this same problem. I cleared it by unplugging the dryer from the wall for 20 seconds and then plugging it back in. After this "reset" of the electronics, it has functioned for 2 days without a problem.
Testimonial: "Thanks - that fixed it!!"
SOURCE: my siemens 7kg dryer s46.51
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off.
SOURCE: I have a Kenmore Elite
Hi.
There is need to test parts. Testing is done with power not connected and using a multimeter. Part of testing requires disassembling.
The problem is usually the door switch. Motor and heating do not start like if the door was open.
Check the door switch. The door switch is tested using a multimeter on switch contacts. The switch must close the circuit showing zero Ohms or little impedance when door is closed. The switch must show Ohms infinity only with door open. Another way to test the switch is by jumping its contacts.
If door switch is OK check belt and motor and thermal fuse.
The thermal fuse is located in the heating group, on top of the cover. The part is indicated with nr.39 in diagram below
The fuse is good if it shows low impedance at the multimeter. If the fuse is gone the multimeter will read infinity.
The belt and motor are reached removing the front panel. Details on disassembly procedure depend on the model number of the appliance.
You can find all diagrams and parts for the dryer entering the complete model number here.
Regards.
Ginko.
SOURCE: Whirlpool duet electric dryer turns on but doesn't
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check outthis electric no heat tip...
heatman101
SOURCE: can not unlock the child saftey locks on my beko tumble dryer
First of all, thank you very much for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for one model of Beko Tumble Dryer (DRVT 71):
http://fiftyeggs.blob.core.windows.net/bekoupload/manuals/DRVT71.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 16 of that manual for detailed instructions and illustrations on how to operate the CHILD LOCK feature on that particular model of dryer. Hopefully the procedure will be similar enough to help you out with yours.
Basically it says to deactivate the CHILD LOCK feature, just press both the START/PAUSE/CANCEL button and the LOW TEMPERATURE button simultaneously, and then hold them both down for about 3 seconds.
Otherwise just comment back here and let us know the exact model number of your machine so we can track down the appropriate information for you.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
child lock is on
To enable the Child Lock feature: Press and hold RACK DRY and ANTI BACTERIAL for 2 seconds. A single DEEP Tone is heard, and CL is displayed. To unlock, press and hold RACK DRY and ANTI BACTERIAL for 2 seconds. The indicator light turns off.
i hope this was useful
