Question about Vehicle Parts & Accessories
Dodge srt-4 2005 rpm fall when accelerate. what can be?
When accelerate the rpm fall and lose power.the engine is hot 180 F or more
  • 3 more comments
  • jose Sep 09, 2012
    the problem still remains. when it is below 170 there are no problems. but, could be the wiring?
  • jose Sep 09, 2012
  • jose Sep 09, 2012
    the cam sensor was replaced and the problem still remains
  • kjosr Nov 09, 2013
    It sounds like its your Catalytic converter is bad on your exhaust system, and that creates back pressure from the engine
  • Big Al Sep 15, 2014
    oil pump
    New Friend:
180 is actually on the low side for a factory temperature setting. An aftermarket performance thermostat can be a 160 or 180 unit. 190-210 is a normal range, 260 is when you need to be concerned. Water/coolant in radiator being hot is normal! That's why you're not supposed to open the cap after the car has been running, wait till it cools off. Not sure on you're problem, more details?
Posted on Sep 07, 2012
    Sergeant:
  • 264 Answers
Agree temp range is normally 190-210. The drop in power could be due to several things. I would check the fuel pressure possibly the fuel regulator has gone bad. Also fuel filter if you push the throttle and the engine reads that it's going to call for more air and fuel so if one is restricted in some way then you will starve on one and the engine will shut back. A vacuum leak will also cause this. Is your vehicle running a little rough at idle ? Also indicator of vacuum leak.
Posted on Nov 06, 2014
SOURCE:
2011 Bajaj Pulsar 135 DTSI engine stalls & loses compression completely when accelerated hard in morning.
Hi, James and the usual suspects are:
1. Improper valve adjustment.
2. Broken or loose cam chain.
3. Loose or broken cam sprocket.
4. Bent, burnt or stuck valve.
5. Blown head gasket.
6. Piston failure.
7. Broken connecting rod.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Got the motorcycle engine overhauled
How to Break in New Top End EnduroNut Method
Bajaj Pulsar 180 DTSi Workshop Manual
Shop At Bajaj PULSAR 135 Bike Parts And Accessories Online Store...
http://shahriary.staffcms.um.ac.ir/imagesm/1064/My_Pic/pulsar_135_ls.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 05, 2017 | 2011 Bajaj Pulsar 150
What makes it not accelerate after a long drive?
lost power, hot/
lots of reasons.
i can list 50 bad parts. or more........
but wont. we do the tests and let the chips fall.
so if the RPM of engine rises, fast , and not car.
that is tranny slip
but if its not tranny slip, then its lost engine power
which is it, we drive car and see that in 1 second.
Jul 06, 2014 | 1997 Lexus ES 300
Loses all power after hitting certain RPM
Not sure what vehicle you are talking about, but I have seen this happen with a dodge caravan that had a poor camshaft sensor. Replacing it cured the issue.
Also, the catalytic converter could be falling apart inside. At higher RPM's the chunks will block the exhaust flow and cause a loss of power. Severe loss of power. I have seen this many times.
Aug 20, 2013 | Cars & Trucks
What's P-0441 code on srt-4.?
The fault code means" Evaporative Emisson System Incorrect Purge Flow"
elm327 bluetooth scanner
Sep 04, 2012 | 2005 Dodge SRT-4
2002 Dodge Durango with code PO478. Engine Galloping
Something has jammed when the engine was lowered to take out the transmission, recheck that area.
Jul 13, 2017 | 2002 Dodge Durango
Car cant go more thann 2 thousand rpm when check engine lightt comes out
when the check engine light comes on the computer goes into limpin mode and limits engine functions. have the car scanned for codes and replace the faulty sensors. Hope this helps. mike
May 28, 2009 | 2005 Dodge SRT-4
Drill support
Hydraulic fluid temperatures above 180°F (82°C) damage most seal compounds and accelerate degradation of the oil. While the operation of any hydraulic system at temperatures above 180°F should be avoided, fluid temperature is too high when viscosity falls below the optimum value for the hydraulic system's components. This can occur well below 180°F, depending on the fluid's viscosity grade.
Aug 27, 2008 | Bosch 10.8V Pocket Driver
Vehicle Parts & Accessories Logo
12,416 people viewed this question
Top Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
