Question about EliteGroup K7S5A Pro Motherboard
Upgrading laptops can any motherboard go into any laptop? same with cpu? cuz i wanna upgrade an ancient laptop its an acer travelmate 505. please help also is there a laptop thats more recent that will be upgradable?
    President:
  • 1,179 Answers
Best upgradeable laptop right now are the high end Dell XPS model line. Hope this helps.
Posted on Dec 24, 2008
SOURCE:
How to upgrade the cpu of my acer travelmate?
Try setting the bios to accomodate the required speed.
Aug 06, 2014 | Acer TravelMate Computers & Internet
Upgrade to higher cpu speed travelmate 270
CPU speed is not going to make much of a difference. You need to increase RAM (random access memory). This will make a huge difference in speed performance.
Aug 06, 2014 | Acer Computers & Internet
What is the fastest cpu which will fit into an Acer Extensa 5420-5687 motherboard?
the fastest cpu supported by the Extensa 5420 series is the AMD Turion x64 TL-66, a dual core with a frequency of 2,3Ghz and 2x512kb of internal cache. You can find more info here: http://support.acer.com/acerpanam/notebook/0000/Acer/Extensa5420G/Extensa5420Gsp2.shtml
Hope it helped,
Franz
Mar 05, 2011 | Acer Extensa 5420-5687 Notebook
I have acer travelmate 2355nxc with 40 gb hdd. want to know how to increase its speed and capacity.
Hi, how are you?
To upgrade your laptop, you will have to verify the capacity for upgrade of your laptop.
The Acer Travelmate comes with:
  • Intel Celeron-M 360 Processor 1.4GHz
  • 256MB DDR SDRAM -
  • 40GB Hard Drive
  • DVD/CD-RW Combo Drive - To read DVDs and CDs and write CDs
  • 15" XGA TFT Screen
  • Intel 852GM 64MB shared graphics
  • Operating System: Windows XP Home Edition
  • Based on this information, you can upgrade your memory depending on what type of memory your motherboard supports and how many empty slots for memory does your laptop have.
    The hard drive can be upgraded also depending on which hard drives does the BIOS will recognize.
    I will suggest to contact ACER and ask for the options and upgrades capacity.
    God Bless You!!!
    Hope it helps.
    Remember to rate solutions, to keep fixya.com working for you!!
    Feb 21, 2011 | Acer Computers & Internet
    Can you do a cpu upgrade on Acer Travelmate 2480-2968? If so what type of intel CPU will work on this machine?
    The following CPUs are supported by the Acer TravelMate 2480:
    Intel Celeron M processor 410/420/430/440/450 (1 MB L2 cache, 1.46/1.60/1.73/1.86/2 GHz, 533 MHz FSB) or higher.
    So, based upon the speed of the CPU you currently have, you can decide whether you need a CPU upgrade or not.
    Nov 04, 2009 | Acer TravelMate 2480-2968 Notebook
    Can We Change the graphic Card of Acer TravelMate 4102 WLMI
    On laptops the graphics are built in onto chips that are on the motherboard, in order to change to the graphics chip you would have to upgrade to the motherboard to something that acer might have.
    Jun 25, 2009 | Acer TravelMate 4100 Notebook
    Acer Travelmate 270 Memory Upgrade
    Acer TravelMate 270 upgrades:
    The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
    The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
    Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
    You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
    Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
    You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
    The laptop absolutely flies with these upgrades.
    Mar 20, 2009 | Acer TravelMate 273XV PC Notebook
    Need to speed up my Acer Travelmate 2410
    According to your describe, your slow TravelMate laptop can caused by various hidden Windows errors. Those problems firstly cause your Acer slow, and then freeze up occasionally. One day crash all of a sudden! To quickly fix the problem, see resolution here: http://www.speedupacer.com/ Should help you out, good luck!
    Dec 29, 2008 | Acer TravelMate 2300 Notebook
    Travelmate 4000 memory upgrade
    Usually the system board will have problems with the 533 Mhz. You will get errors and/or may not come up at all.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Oct 13, 2008 | Acer TravelMate 2300 Notebook
    EliteGroup K7S5A Pro Motherboard Logo
    57 people viewed this question
    Top EliteGroup Computers & Internet Experts
    Alun Cox
    Thomas F. Schneider
    Ekse
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
