There were sparks flying off the pole of the power lines behind my house so I am guessing we got a power surge. LG Refrigerator (LFC25760ST) not cooling now. Warm in Fridge. Freeze is still cold but seems to be melting slowly. No air circulating. Here is what I have done but I really how no idea what I am doing: I pulled off the rear panel and vacuumed around but it wasn't real dirty anyways. What I am guessing is the condenser seems to be running and is warm/hot. Fan is running. I pulled off panel to circuit board and fuse is OK. Pressed button on circuit board which seems to display error codes on the panel in the fridge. The codes are as follows 888, 222, 333. Help!
Call a technician because either a board was burnt out or the compressor or the start device for the compressor took an excessive load and is shot.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
SOURCE: LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
SOURCE: Inside top of refrigerator hot light don't turn off.
There is a service bulletin related to this, dealing with deformation / melting of the lamp cover. The fix is to change the lamp wire harness to one that now has a thermal protector incorporated in it (part number 6621JK2003B) along with changing the main PCB board to one that uses a larger relay for this function (part number 6871JB1423N).
In case you want or need to replace the following,
The lamp cover is part number 3110JA1096A and the lamp holder is part number 3034JA1009A
I tried to cut and paste a few photo's, but was unsuccessful. Sorry. Make sure to test that fans and light switches work after part changes.
SOURCE: my fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
3.4L Engine
Let the Fridge defrost and seems to be coming back. Crossing my fingers!!!!!
Help defrost was all that was needed.
