I am having trouble locating the control panel for the refrigerator. Is it under the light panel?
If the defrost timer is a control board, then you won't be able to manually set it, get the model number from inside the refrigerator and go to www.partselect.com and there you will be able to get a full illustrated blow out of the machine and locate the part your looking for
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Kenmore Fridge #596
i found the defrost timer for my Kenmore 596.62239200 / freezer on bottom. it was in the top of the refrigerator compartment behind the light bulb console. had to remove the light bulb cover and then there are two visible screws that hold the defrost timer to the light console. the timer is up on top of the console and is not easily seen. ordered parts on www.repairclinic.com.
SOURCE: Freezer/refrigerator compressor running constantly
th ebi-metal is a thermostat which shuts the defrost heater on/off, but doesnt actually put the unit into defrost. if it were bad the defrost heater would never go on resulting in massive build up of ice on back wall of freezer, and noticable refrigeration sect. cooling.. dont know how you know the compressor never shuts down, but if that the case perhaps you have a sealed system/ freon issue. try removing the back panel of freezer section and check the evaporator coil. you shuld have an even frost pattern over the entire evap coil. if theres just frost over the top 1or 2 coils, and the rest of coil is shiny aluminum , thats an indication of a sealed system issue.( 5 year part warr by manufacture) def not a do it yourself issue...but that would,, depending on extent of restriction/loss of freon,, cause freezer to freeze and defrost eratically,and the compressor would be running constantly trying to achieve a good stable temp
SOURCE: Refrigerator Defrost Troubleshooting
you cannot do this
just check the defrost heater and the bi metal, if they check good then the adaptive defrost control is bad
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
SOURCE: How to check defrost timer on Kenmore side by side
You don't have a defrost timer, you have an adaptive defrost control which determines when to defrost based on how often door is opened etc. If you have a defrost problem check
, defrost heater, defrost thermostat
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the heater and thermostat are ok it’ll be the control.
Testimonial: "Thank you"
