All the settings are right ang I added oil, but it still won't start when I pull the cord. It sounds like it won't turn over.
SOURCE: power washer not starting what type of oil to use dpd3100
10 w 30 for engine
10 w 30 and specify for [PUMP OIL]
ANY AUTO STORE
THANKS AND PLEASE RATE JJ505
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
Good luck
Regards
PCmania
SOURCE: How do you check oil in pump on Dewalt DPD3100
There is a little window on the side of the pump to see the oil level but thats normaly the problem None of these companys make there owen pumps or engines i owen serveral power washers if you can tell me more about the problem Iwill likely know how to fix it see who made the pump and the engine and let me know pier_j
SOURCE: I have a Dewalt DPD3100,
Take the hose off the gun and see if water comes out. If so the gun has to be taken apart and cleaned. Also where the water hose goes in to the machine there is a screen filter which you might have to clean if water is not comming out on the gun side. Use a screwdriver and pry it out carefully around the edges Clean the screen with a wire brush and put it back in and try it.
Loosen the chain so it can be carefully moved by hand. If it moves pull out the spark plug. Sometimes oil and or fuel will collect in the cylinder and will cause this.
