If this an under the counter ice maker the machine is going to run water all the time with the exception of when the ice slides down to the cutting grid to be dropped.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
SOURCE: Ice maker not working
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
SOURCE: Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
SOURCE: no ice in the icemaker
there may be some problem with water inlet solenoid valve. the coil or valve could be faulty
SOURCE: Icemaker is not making ice
check the fill tube on the ice maker to see if its frozen upo. if it is you are going to need a new solinoid valve due to it leaking thru the valve and freezing up.
SOURCE: ice maker not working ; water dispenser ok
The reason could be several different possibilities. the water control valve for the ice maker no longer works or one of the many components inside the ice maker is needing replace or adjusted. Go to link below and enter model ED5VHGXM into model search. Click on photo #12 ice maker and you get a breakdown of of all the parts. Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
