Refrigerators Logo
Anonymous Posted on Sep 05, 2012
Model jrsd2250 need condenser motor number
Need condenser motor number
Jason Kennidy
Level 3:
  • Master 1,344 Answers
  • Posted on Sep 06, 2012
Jason Kennidy
Master
Level 3:
Answers
1344
Questions
0
Helped
370181
Points
4021
Pt# 833697
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
  • Anonymous Sep 06, 2012
    the # is right thanks
  • Jason Kennidy
    Jason Kennidy Sep 06, 2012
    no problem
1helpful
I need the p/n for condenser fan motor on Rudd modelUama-042jaz serial number 5074m34959254. I’d like the number to original motor
You can look on data plate or sticker on motor or you should google
Ruud modeluama-042jaz condenser fan motor for answers. the OEM part number is 51-100998-30.
You can find answers by googling any question..
I have a American standard ac model 7A0018-60A100A and would like to know the model no. of the condenser fan motor so I can replace it
All you need to know is that it is a 1/4 hp, 825 rpm. 1/2 inch shaft. That is if you are going to buy an after market motor. I have had to make new mounting holes when using after market motors on trane systems (just the way trane is) but not a problem. If you're getting it from trane you would only need the model number of the condenser.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2answers
If the refrigerator door seal is hot does it use more electricity?
No there is warm freon circulating in pipes called a yoder loop behind the metal door frame to prevent condensate. What is the model number of your fridge? On some models it is electric and there is an option to turn it off
APPLIANCE 911
Why is my sub zero freezer not cold enough?
Although I have no model number to assist you, cooling issue have many possible causes. Here are a few you can check: dirty condenser, non working condenser fan motor, hot compressor, bad compressor, bad cold control, bad or failed evaporator fan motor, etc..
So a model number gives use a better look into the issues you have. Check all components listed here and determine what is not working for you. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
The model number is 10532
The serial number is 01749
1helpful
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Ac blower motor attic
that is a model number for the outside condensing unit. to find the motor size for the inside unit, you will need the model off of the inside unit, gas furnace or electric air handler.
Condenser fan motor
It would be easier to get the data from the condenser fan motor than attempt to match AC unit model numbers. If unreadable then remove the fan motor and take to someone to match with the one you have. That is what I do, Thanks Sea Breeze
Make sure you mark your wiring before removal.
2answers
In winter the refrigerator make ice not in summer, just cleaned the evaporator which was totally cove with dust, noticed also that the compressor is hot and all the coopper pipes also are very hot, what...
The reason everything is hot is because you stopped the unit from "Breathing" through the condenser (not evaporator) by allowing dust to build up.
This is how the system disperses heat absorbed in the freezer section (evaporator).
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
