A towel was placed on the outside part of the air conditioner blocking vents, ran for hour like that. Now making noise from I think the fan.
SOURCE: Frigidaire FAH106N1 Thru-Wall/Window Air Conditioner
Check for blockage of the air pathway. Check that the fan turns freely, as the bearings or bushings could be shot. The fan blades could also be loose. You might just want to replace the fan, as it is cheaper than replacing bushing/bearings.
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
SOURCE: Does the Frigidaire FAC 126P1A need to be vented?
It must be installed in a window openeing or through the wall.
A load bearing wall is no problem.
Cutout the opening larger than the unit and install a header in the wall cutout.
SOURCE: frigidaire wall unit- 4 years old air conditioner
try a fan run capacitor ,,,and the a new fan ,see if fan is stif to turn by hand if so replace fan
SOURCE: do you need brackets for outside wall installation
No you do not. Not a bad option, but if wall sleeve nstalled properly this unit will not need brackets.
