Laptop wont turn on. AC adapter has power. I have replace the dc jack but still no power?
Remove the battery and AC Adapter cord, and press and hold the power
button for 30 seconds. Then, without replacing the battery try plugging
in your AC Adapter to see if you get any love. If that doesn't work,
remove the AC adapter, reset the board again, and this time hold the
power button down as you plug in the AC Adapter cord. If you still don't
get any lights, you could try removing your memory, reset the board,
replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Problem symptoms:
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Problem symptoms:
