Question about Samsung RM255LASH Side by Side Refrigerator
Model rs2533sw panel not reseting after being unplugged
Unplugged unit to replace fan to refrigerator pluggede unit back in to power source and panel will not come on.
  • rcasey84 Dec 26, 2008
    buttons for 9 seconds
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Posted on Dec 30, 2008
  • 700 Answers
Did you wait for 9 minutes and or did you take and press the top two buttons for about 12 secends and reset the uniot?
Posted on Dec 24, 2008
6ya staff
SOURCE:
Samsung rb215abbp won't stop beeping. I recently switched the door from the right side to the left. Now my fridge says 66 degrees but is cold. Light is on only when I unplug and plug it back in.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Sep 30, 2016 | Samsung Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 25, 2015 | Refrigerators
Samsung model#rs2533sw the freezer is freezing but display reads 64 want does it need????
it needs one of a few things
do this first
open the doors take all the food out
and move it /use it
and then defrost it doors open for a couple of days
now take out all the furniture inside it shelfs etc
so at the back of the freezer unit
is a panel it will have 4 or 6 screws or caps
you need to remove the caps/ screws clips
behind this panel is a fan and the freezer unit
perhaps the fan has failed
you can take the panel off
and check for an ice monster stopping it moving
so if there isnt one
power on and see the fan should spin up
if it doesnt the fan has failed {quite common}
so once you replace the fan with either a universal type
or a oem then it works the frost water ways its a V shape below
has a tube that connects this waist water to an evaporator tray mounted on the compresser at the base
so clean it all and the tube and dress it will salt
do the same for the drain on the fridge unit
and mount the back cleared of any debri about 5" from the wall and with good circulation
well you did ask whats up and how to fix it...!!
Dec 20, 2014 | Refrigerators
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
Similar problem last month.i replaced the heat element in the freezer section.now both the fridge and freeze will not get cold enough.also i hear not fans or compressor? model ge pss25ng
If you are not hearing any fans or compressor try to unplug unit for about 1 minute. Plug unit back in and see if it will start. If not the main control board located on the back of the unit under a metal plate has gone bad and will need to be replaced WR55X10942 is the part number at approx. 165.00 The reason for the unplugging of the unit was to try to reset the board. Some times a small power surge will lock it out and it has to be unplugged to be reset. Hope the power restore helps. Good luck and thanks, Rick
Mar 02, 2010 | GE PSS26SHRSS Side by Side Refrigerator
Samsung double door refrigerator/freezer is not holding the tempature in the refrigerator. When you attempt to reset the temperature and press "power cool" nothing... temp remains around 56 The freezer...
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Jun 15, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung model rs2533sw control panel not coming on
http://www.fixya.com/support/t1914675-control_panel_not_working_samsung
Nov 30, 2017 | Refrigerators
I have a Samsung side by side refrigerator RS2533SW and it stoped cooling both sides. I already tried to reset it. That did not help the fan is kicking on an off. Do you have an Idea. Thanks
check to see if the fan and compressor in the back conme on first. if they do then shut the unit off and remove the back panels inside and thaw out the ocils.
Feb 02, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Samsung RS2533SW freezer not cooling problem
I was having the same problem but with the refrigerator side. I know your problem was with the freezer side but I hope this works in your situation too. I was also told to unplug the fridge for 20 minutes and that did not do a thing to reset the circuit board in my situation. Unplug the refrigerator first. In the back of the refrigerator at the bottom is a metal panel. Remove that panel and off to the right side of it should be a white looking plastic box. Unscrew that box from the fridge and open it up to get to the circuit board. Remove ALL harnesses from the circuit board and capacitor. After doing so plug them all back in and reassemble everything back together and plug in the fridge. This should reset the board and allow it to function correctly. This is advice I got from someone else and everything as of today is cooling down like it should. I hope this helps everyone else out. Best of luck.
Also since the evaporator was frozen solid at the bottom on the refrigerator side I had to leave the power off until it thawed and then had to soak up all the water that collected at the bottom of it.
Dec 02, 2007 | Refrigerators
Samsung RM255LASH Side by Side Refrigerator Logo
1,044 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
