The belt of my dryer is broken and I can't find a change part. Can someone give me the name of a supplier or the manufacturer ? Thank you
The belt is a 341241. You can get one on Ebay
How to tuneup and belt replacement
My home movie shows row to replace it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: whirlpool dryer epny spin belt not broken
althoug intact was it taught???? perhaps it "popped " off the idler/tension pulley. or if hte unit appears dead, then oyu either have a bad door switch/ or a fautly thermal fuse behind the unit.
SOURCE: How do I fit a new belt to a Whirlpool AWZ650?
Found this dead easy, take top off and back off. Inside undo the star shaped screws, there are also a few screws that are a different shape when removed, these secure the back to an air inlet. Suggest you take note of where the screws come from, even write a number next to the hole with a marker pen and note which screws and in what order. There is also an earth attached to the drum, this is the only wire I removed. Take this back section off. You should then be able to remove the drum by wiggling it out and turning it sideways in the dryer casing.Then remove the fan bottom left, 4 screws and a clip in the centre, the clip was difficult to remove without spreading it so you may need to squeeze it back into shaped before putting it back on. The tensioners will probably have come out of their locators so put them back into place, this is easy to see when you look at them. This is proabably a good time to vacum any dust out. Spread the tensioners hook the belt over the drive shaft only, not the tensioners, and let them spring back, these will then spread when the belt stretches around the drum. Put the drum back on and pull the belt around it, make sure its lined up with the original belt markings otherwise it will just pull the belt off of the drive shaft. Put all the screws back in attache the earth to the drum and put the back on then the top on. I'm not a technician and haven't done this before, it took about 1 1/2hrs.
SOURCE: whirlpool electric dryer tub won't turn. Belt is
if you are hearing loud buzzing or loud humming when start switch is engaged,u have 2 possibilities:1. a bad motor. 2.something hindering the motor's ability to turn.most likely cause of this is usually something caught in the blower housing,preventing motor from turning
SOURCE: have to replace broken belt on a whirlpool awz
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
