Can not shut down search get busy message. shutting down can cause problems. how do i shut down?
SOURCE: acer laptop aspire 4710z config my notebook have problem
hello ramavtar..
i have a acer aspire 4710z. This laptop can not open the display but the system unit is working normally. i can not see the display but i can join the external monitor i will see it process. Pls let me know how can i repair it.Pls reply to this email thanks. [email protected]
SOURCE: IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
SOURCE: Lenovo Laptop Stuck up while shut down
let it set if u turn it off by the buttons while its shutting down u'll have to format hard drive and reinstall you system
SOURCE: Sony Vaio Laptop vgn-sz330p does not shut down
This problem is generally caused by a hanging program or the registry is corrupt.
The best way i have found to resolve the problem is download a small program called "Superfast", not only does it shut XP down it does it in half the normal time and doesn't effect the computer in any way.
Download and install Superfast here >>>>>>>>>>
http://www.download3k.com/Install-SuperFast-Shutdown.html
Once you have it installed try it, you'll be amazed!!!
Regards.
