It is the Weiser Lock Powerbolt 1000 Lock.
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
SOURCE: center button unlocks insted of locks code locks insted of unlock
Take off the inside cover and move the door direction jumper over one pin.
SOURCE: How do I reprogram the
best of luck.
SOURCE: powerbolt does not lock, motor operates but
your may just need a new battery. im not familiar with that model but the one i had would blink the lights when the batt was low.
SOURCE: Touch pad does not work on weiser lock powerbolt.
I found this Frequently Asked Questions sheet for the Powerbolt 1000:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
I hope this helps.
