I tried customer support chat and tried turning both units off and on again, nothing is working. I get the message on my iPod "This accessory is not supported by iPod Touch". I have a 4th Gen iPod touch, which is supposed to be compatible with this unit.
SOURCE: is there an update for
Yes just go to: http://esupport.sony.com/US/perl/swu-download.pl?upd_id=5885&mdl=ICFCL75IP
This is the version 1.05 update on Sony's site along with instructions on how to install it.
SOURCE: i have the ICF-CS10iP dream
Please check the iPod connector on the Sony. If you can wiggle it, it is
probably a bad connection. These models Sony radios have the connector
directly soldered on a PCB and it tends to get loose after a while due
to connecting/disconnecting the iPod. If it is loose, the connector
needs to be resoldered back into place.
I have had the following circumstances when there was a bad connection:
- iPod will not be charged
- iPod can not play music through the Sony
- iPod will play music through the Sony, but an iPhone won't
SOURCE: my ipod wont play through
probably a bad connection. These model Sony radios have the connector
needs to be re-soldered back into place.
SOURCE: Sony ICF-DS11iP doesn't play my
Please check the iPod connector on the Sony. If you can wiggle it, it is probably a bad connection. These models Sony radios have the connector directly soldered on a PCB and it tends to get loose after a while due to connecting/disconnecting the iPod. If it is loose, the connector needs to be resoldered back into place.
Did you ever get an answer or find out how to solve the problem? We are getting the same error message on iPods that we recently updated.
