Cars & Trucks Logo
Anonymous Posted on Sep 04, 2012
What's P-0441 code on srt-4.?
This occurs when hot engine temperature.
allobd2
Level 3:
Genius:
  • Dodge Master 1,207 Answers
  • Posted on Sep 05, 2012
allobd2
Dodge Master
Level 3:
Genius:
Answers
1207
Questions
5
Helped
420447
Points
3657
The fault code means" Evaporative Emisson System Incorrect Purge Flow"
elm327 bluetooth scanner
2011 jeep cherokee spark plug firing order
coil pack problems?
new cam timing questions?
no PROBLEM told all , so I answer blind and dumbb.
we (USA)_ have no Cherokee here, 2011, are you in UK or India or?
the Cherokee brand came back to USA in 2014,so you are not here.
got yah. or
or forgot it is GRAND.? << this>? or the SRT engine ?
pulled the coil pack wires all at once.
sure. never do that, it's 1 by1, but is not using old 2000 coil packs.
no engine told at all not even v6 or v8 or size told
no vin told so i can tell you what is under that hood.
google vin decoder and see for your self first
our GRAND has 4 engines, 1 is diesel so not that.
our GRAND is
3.6L 1 - 2 - 3 - 4 - 5 - 6. uses COPs, no coil packs just 6 cops o
5.7L 1-8-4-3-6-5-7-2. uses COPS. the PCM and harness break outs set order.
5.7L USA has twin COPS, 2 per bank 4 total. and going plug in one way.
6.4L 1-8-4-3-6-5-7-2. ditto. seems not sold in USA. ( data is hard to find on it)
6.4-liter SRT HEMI V8 engine that is only available on the Jeep Grand Cherokee SRT.
1helpful
Why does my oil light stay on when giving it gas and goes off when idle
the oil sending unit grounds out the dash light bulb as engine speed increases the pressure rises and turn light off normal idle hot oil pressure 30-40 psi. if low then engine bearings are worn.
P 1401 location
Codes don't have a certain location, a code means a problem has occurred in a system of the electronics of the cars fuel control or emission control system.
P1401 NISSAN - EGR Temperature SensorPossible causes- EGR Temperature Sensor harness is open or shorted
- EGR Temperature Sensor circuit poor electrical connection
- Faulty EGR Temperature Sensor
- Malfunction of EGR function, EGRC-BPT valve or EGRC-solenoid valve
- Blocked EGR passages When is the code detected?An excessively low voltage from the Exhaust Gas Recirculation (EGR) temperature sensor is sent to Engine Control Module (ECM) even when engine coolant temperature is low, or an excessively high voltage from the EGR temperature sensor is sent to ECM even when engine coolant temperature is high.
P1401 NISSAN Description The Exhaust Gas Recirculation (EGR) temperature sensor detects temperature changes in the EGR passage way. When the EGR valve opens, hot exhaust gases flow, and the temperature in the passage way changes. The EGR temperature sensor is a thermistor that modifies a voltage signal sent from the Engine Control Module (ECM). This modified signal then returns to the ECM as an input signal. As the temperature increases, EGR temperature sensor resistance decreases.
This sensor is not used to control the engine system. It is used only for the on board diagnosis
No heat, Service Engine Soon light came on, Engine and Colant still hot 3hrs after shutting it off what could be the problem ?
Hello Eric...
As you do not have heat, one or more heater & AC air delivery and/or temperature mode door actuator may have failed. This can result in incorrect air delivery or temperature. If this occurs, fault code(s) will be stored in the HVAC control module and should be recovered (A code reader is required) to assist with diagnoses.
Engine noise once and a while
If the check engine light is on, I would take the car to an autoparts store and have them use a scan tool to retrieve any fault codes stored in the computer. Most parts stores will perform the scan for free. Getting the codes will show any engine faults that the computer has identified. Hope this helped and best wishes.
6helpful
2answers
P0522 engine code with oil ligth on 2005 SRT 4
By any chance did this start after an oil service. Could be the wrong oil. But my first guess is the wire at the sensor may be loose or the sensor is bad. Oil pressure sensor. Best bet is to have it looked at by a pro because Chrysler has had lots of problems over the years due to oil issues. I'm talking engine destroying oil issues. I'm not saying be concerned but be aware of this in order to make your best decision
1helpful
Car wont move!
Sounds like the trans input shaft may be broken.If the input shaft, which is connected to the clutch, is not transmitting rotation to the inside of the trans then what you describe will occur.
2004 Dodge SRT-4 keeps coding out
What code number? It could have a wiring short or open to the PCM or to ground. Cam could be out of time, check the timing belt.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
