Spins back and forth and drains but does not extract spin fast
SOURCE: My washer won't complete the final spin cycle. It
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
SOURCE: fridgidaire model fwx223lbs4 will wash, but won't spin fast and the water won't drain
HI thanks for the question it sounds like the pump is either burnt out or jammed with debris thanks the appliance doc
SOURCE: not draining all the way. slow spin
I had the same problem. There was a sock stuck in my drain hose! To correct it, I did the following:
Hope that helps you! I feel good I spared myself a visit from the plumber.
SOURCE: Fridgidaire Gallery Series Front Load washer won't drain or spin
It sounds like there may be 2 things wrong. If the drier is not draining then the pump is clogged. Remove the drain hoses and check the pump(IMPORTANT!!!!Before you remove the hoses get a pan to put under the hoses. Alot of water will go on the if you do not do this...)The pump most likely has a coin in it.
The klunk you heard... If the drum spins and seems to be out of balance. If could be your rear bearing or your spider bracket.
