Sewing Machines Logo
Claudine Kennedy Posted on Sep 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can I get the material to move forward when machine operating?
The needle is sewing but the material is not moving forward, just at a standstill? What could be wrong. Many thanks. ck
Debbi's Sewing Machine Repair
Level 3:
  • Sewing Machines Master 7,365 Answers
  • Posted on Sep 05, 2012
Level 3:
Answers
7365
Questions
Helped
1744272
Points
19451
The feed dogs are not working, they hold the fabric against the
presser foot, so the fabric is moved forward,they are in the needle
plate, they should be seen & felt in the center of the needle plate.
5 Related Answers
Anonymous
  • 15 Answers
  • Posted on Dec 10, 2007
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Anonymous
  • 323 Answers
  • Posted on Jun 12, 2008
SOURCE: The fabric doesn't move forward.
We need to do some examining. Remove the foot. Put the stitch length dial at the longest stitch. Turn the wheel and see if the feed dogs move about 1/4 inch. Also check to see that they rise just slightly above the needle plate. If it does these two things it will work. If the teeth don't rise above the plate, remove the needle plate and clean the lint out from between the rows of teeth. If you find a lot of tightly packed lint there this will solve your problem. Reinstall the needle plate and foot. If the feed dogs don't move about 1/4 inch, you probably have a problem which is going to require the services of a technician.
sewman7
Anonymous
  • 35 Answers
  • Posted on Aug 16, 2008
SOURCE: material doesn't move
Are the feed dogs engaged? Janomes usually have a feed dog sliding switch, either on the back of the sewing machine at the bottom, or behind the accessory case. Be sure the check it out. Hope this helps!
A
Anonymous
  • Posted on Sep 25, 2008
SOURCE: machine works but doesnt move forward
Could be that the feed dog is in the down position. The feed dog consists of serrated sections which move together under the fabric and move it under the needle. Run the machine unthreaded and you should see the serrated sections lift above the needle plate, move forward and then drop again. If this doesn't happen the "drop feed dog" knob on the front of the machine could be pushed in. Look for a small knob about 1/2 inch across on the right front of the machine. Push on it and move it sideways at the same time. If it pops out this means that the feed dog is now up and you should be able to sew.
Anonymous
  • 323 Answers
  • Posted on Feb 16, 2009
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
I have a new ruby sewing machine the material will not pass under the foot. The needle just goes up and down in one spot
Make sure the stitch length is set high enough to actually move the fabric. Also check that the feed dogs are actually moving forward and backward when stitching (they should move from front to back, then drop below the needle plate and move to the front, where they rise again,)..
1helpful
Lervia sewng machine. material wont feed through. Dogs are up but material just wont move through. needle moving freely.
Hm, could be several things. If stitches are not being formed, it could be a timing issue (the needle does not arrive at the bobbin at the correct time). Did the machine recently hit a pin or something hard? That will knock a machine out of time. There could also be a broken piece stuck that is preventing the feed dogs from operating. Thoroughly clean the machine around the bobbin area and feed dogs.
2answers
Bernina 440
The jagged teeth on sewing plate are not moving to move the material forward. U will have to look under the machine to check out the mechanism that is supposed to move them and find the part that is the cause of no transmission of power to the teeth assembly.
How do I stop my needle from breaking and how to I see to it that the machine is self feeding the material forward instead of me having to pull it towards me to get the stitches into the material?
The needle may be bent, but surely the material should feed away from you not towards? Is the bobbin in correctly? If you have inadvertently left the feed dogs down the material will not be gripped and stay in the same place instead of moving. Check.
Teeth do not move material forward when sewing
the problem is the feed dog is in the wrong position,, in the operation manual it should tell where the feed dog is on that sewing machine, & what position it's suppose to be in to sew normally
Hi I thread the machine as normal and begin to sew, the material moves forward under the foot but stiches are not forming
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Material will not move forward
Make sure the presser foot is coming all the way down. Check your stitch length setting too.
1helpful
Very old Necchi sewing machine - sews in place
sounds like the feed dogs may be down or not working. Watch to see if the little teeth are moving under the pressure foot when you stitch( try to run unthreaded and with foot up no fabricto check) May be a button to turn up the feed dogs.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
