My iomega works fine on my pc. it recognize it and all works well. the problem is when i connect it to my tv it starts beeping and the tv won't recognize it. what should i do?
SOURCE: my iomega beeps evert time I connect it to my PC
Hey did u got Y cable with the drive or just normal cable. If you received the Y cable make sure you connect Both power( with the White bolt sticker) and data ends
SOURCE: Well my problem is that
you might have to uninstall the express card restart your computer then reinstall it also make sure its clean and securely seated and there is no dust built up
or it might be trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
SOURCE: Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
SOURCE: my iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
