Click the link below for help
http://www.youtube.com/watch?v=ps6dPxoxe9c
SOURCE: we have a seth thomas
1, Wind the clock. If the pendulum still does not swing, check the hands of the clock. If the hands are touching each other, push the hour hand gently toward the clock face. If the hands still touch, gently bend the minute hand away from the clock face.
2. Examine the swing of the pendulum. If it moves, and then stops, or if it swings erratically, the clock is probably off-balance. Gently tilt the clock to one side and restart the pendulum.
Watch the swing of the pendulum. If it stops again or continues to swing erratically, try tilting the clock in the opposite direction. Tilt the clock at various angles, on each side, and front and back, until the pendulum runs smoothly and regularly.
Note the clock position in which the pendulum swings freely. Place a wedge underneath the clock in the place needed to maintain this angle. If a wedge alone will not hold the Seth Thomas grandfather clock in the proper position, try lifting the clock slightly up against the wall.
Use a screwdriver to attach a bracket to the wall at the appropriate position. Additional brackets may be needed depending on the angle required. It may also be necessary to employ a combination of wedges and brackets.
SOURCE: I inherited a grandfather clock which runs slow
You have to adjust the bob on pendulum. If the clock is slow, the bob on the rod must be pushed up. If the clock is fast, the bob must be pushed down. Do adjustments bit by bit, day by day till the clock is keeping time. If all this does not work, you may need to replace suspension spring (if there is any). If there are no suspension spring, the clock may need proffessional attention.
SOURCE: I'm just wondering if someone
I know nothing about clocks, but found a great website for you.
http://www.howtorepairclocks.com/
Good luck
SOURCE: the clock time cannot be set on a
You question is a bit non descriptive except that the clock does not work and the hand clutch has failed.
GOTO:
http://www.nawcc.org/business-directory/
Hopefully this will guide you in the correct direction for a local repair person.
Hope this tip helps
R/
David
clock is not a harley davidson . It is a Viking Model #76, ,461-050,unadjusted ,grandfather clock. Made in west germany
