Question about Sony RM-ASP001 Remote Control
Sony RM-ASP001 for 400 disk changer stopped working
I was using the remote to program the DVD player and it was working fine. Then it got bumped by someone walking by and the batteries fell out, (lid for battery box is missing). I put the batteries back in and it no longer worked. I replaced the batteries but it still didn't work. I tried a different remote on the DVD player and that worked fine. I tested the sony remote using a digital camara and the light worked ok for all buttons.
I hope someone here may have an idea as to why the controller stopped working.
Regards
Will
  • Anonymous Mar 20, 2009
    I had the same problem. I have the dvd player controlled through niles infrared so I could see that it was getting a signal but it wasn't doing anything. I moved the command button in the remote to 2 and 3 then back to 1 and it worked. Then it went out again and I did the same thing...it didn't work. I did it again....it worked
  • Tony Garcia
    Tony Garcia Apr 09, 2014
    Got mine working just minutes ago!!! I was going crazy! Tried resetting settings on remote with no luck. Did the moving back command button several times like 5-6 times. It worked!! I was about to send this is in or just give up on it! Thanks fixya and will
Try the command code switch. I recently had a similar problem when my remote suddenly stopped working. It worked fine one time but nothing the next time I tried it.
I checked the emitter with a digital camera and found it was not working. I did the remote reset (remove batteries and push all the buttons twice, reinsert batteries) and the emitter was now working. However, the remote would still not control the base unit. I did the remote base code reset (push power, volume and TV/DVD buttons together) but this did not help. I then checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. I did not change anything on the base unit but the remote now worked.
Hope this helps.
Posted on Dec 26, 2008
  • Melody K Jul 17, 2014
    Thank you, thank you, thank you. I was just about to buy a new remote. Your suggestions, of which I do not know worked, fixed the problem. Now it is working again.
The solution provided by alexlindsay worked for me! I was prepared to spend $40 on a new remote, convinced mine was shot. All I ended up doing was removing the batteries, hitting every button twice. That did not fix it, but then I did what they said - I checked the command code switch. This is a small three position slide switch located in the battery compartment on the remote. I slid the switch back and forth several times returning to the default number one setting where it was before. That fixed it! I think it may be important to slide the switch back and forth several times - just a couple of times did not work for me. Thanks alexlindsay!
Posted on Feb 08, 2009
  • 2 more comments
  • thirdear Dec 25, 2010
    3rdear's Blog
    12/25/10 - As with TheGrandMark I too was looking at putting out $40 something to replace what I thought was a shot remote, but, GODBLESSGOOGLE, I found this site and right off the bat someone described the very problem I was having! I read the solution offered by alexlindsay and, it being the least convoluted, I tried it first...Bingo! It worked. My remote is back online and I haven't deprived my family of 40 hard earned bucks on Christmas Day. MANY THANKS, ALEX! HAPPY NEW YEAR!
  • Tony Garcia
    Heck YEAH!!! After about two years of sitting without any use. My remote died. I tried everything. But looked online and this page caught my eye. I previously changed the settings on the remote in the battery area. But didnt work. I tried several times as suggested here!! And Im back in business. This info was not in the manual anywhere!! I love this fixya page!! April 9, 2014!!!
  • jeff_shores2 Mar 31, 2015
    Perfect! Sliding the small three position slide switch back and forth worked! Thanks!
  • Barbara Shissias
    Barbara Shissias Nov 09, 2015
    Thanks a million Alex! I just had the same problem and fixed it in about 10 minutes! Auntie Babs of Auntie Babs Estate Sales and More... In Somerset, NJ
Our remote had been not working for a few months.
Today, in another attempt to either price a cheaper replacement or a fix, I happened upon this site.
I tried the series of fixes offered on this page, with no success.
On a whim, I decided to try the 3 position switch in the alternate positions. I figured I had nothing to lose if the remote was truly broken. I tried position 3 with no success.
I put the switch in position 2 and tried it and it WORKED!
Posted on Feb 05, 2011
  • marklandtile Apr 30, 2011
    It worked! switched it back n forth and replaced the batteries. Thanks again
I too lucked on this site after not dealing with a dead remote for a number of months. I was going to find a replacement today, and came across this site. I love FIXYA!!!! I tried everthing suggested. I worked the 3position switch in the battery compartment a number of times. Just on a whim I tried the other settings, and #3 worked for me. I'd sugesst put in new batteries and work the switch some, and then try all three numbered positions and you might find one the works!!! thanks again and good luch to others who have this problem.
Posted on Dec 31, 2012
    New Friend:
I had the same issue as everyone else here. I put my Sony 400 disc Changer in storage between moves and when I set it up at new home the remote would not work. I too was ready to buy a replacement remote because the original is no longer made. I came upon this site and tried what others have suggested. I moved tiny switch in battery compartment probably close to ten times with no success. I then moved it few more times and tried position 2 and 3...nothing. I then turned the unit on at the base and tried positions 2 and 3 again....nothing. I then put it back in default position 1 and walla the remote worked and turned the base off. Just to be sure I turned it on and off several tines with the remote. Word of advice keep trying!
Posted on Jun 02, 2015
    New Friend:
I followed the advise of others here and it worked! Move the command switch under the battery compartment, several times 4-6 total. Put batteries back in and whalla!!! it works!! Thanks fixya and everyone here with their personal experiences.
Posted on Apr 09, 2014
SOURCE:
I want to program my duraband 1002 dvd player to my dish network remote does anyone know a code that will work?
It's been a few months, so I am hoping that you were able to find the code. But if not, below is a link that will not only give you the available codes, but also walk you through programming the remote to the player.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Becki Barned
DISH Network Customer Service
Sep 18, 2010 | Durabrand DVD-1002 DVD Player
I cannot open the part to place the DVD in the player. How can I fix this problem. It was purchased this way and has never been used.
Look for a button on the DVD Player said OPEN.Push that button,will open the lid to place in the DVD disc.Or no button siad OPEN.Look on the lid itself,look for a small **** on the DVD player lid or a bump on the lid.
Aug 11, 2010 | Amphion Mediaworks M-270 Portable DVD...
My remote for my coby dvd player stopped working and i am trying to program my rca universal remote to use it. my actual remote that came with my dvd player is not working. i switch batteries because i...
One or more button of the remote may be sticky and touching together.
If this happened, the remote will not work.
Remove the batteries and press all of the buttons at least 2 times.
This will free up all the buttons.
Install batteries and try remote.
Jun 22, 2010 | Coby DVD-224 DVD Player
Universal remote + Quasar TV = no luck. pls help!!
Do Research on the remote with the tv brand name in google. you will find something such as an manual.
Jan 05, 2010 | Televison & Video
Disc stuck
usually to reset remote remove batteries and short the + and - terminals together or leave batteries out for about ten minutes this should get rid off any programmed codes.
Oct 02, 2008 | Philips Magnavox DVD/VCR Dual Player
Bush DVD 2038 DVD player
I contacted Bush custimer care and this is the reply I got:
We apologize for the inconvenience caused to you.
We would request you to kindly reset the remote control by following the steps mentioned below:
1. Remove the batteries and reinsert the batteries after 1 minute.
2. Press and hold the top, right and the bottom navigation button on the
remote control along with the number 1 button (as in 123) for 10sec.
It didn't work for me, but I have posted it on here, just in case it works from someone else
Feb 02, 2008 | Televison & Video
Coby dvd 514 remote
BAD NEWS.....I READ THIS FROM THE COBY PRODUCTS WEBSITE: COBYUSA.COM..... What is the code to program my Universal remote with my Coby DVD player? There is no code to program our DVD players with your Universal remote, you need to use the remote that came with the player.
Aug 27, 2007 | Coby DVD-514 DVD Player
Codes to program a universal remote to this device
You can try the following four digit codes:
0670, 0695, 0873, or 1919.
Aug 13, 2007 | Sanyo DWM-390 DVD Player
Remote
if coby is an independent company you are out of luck. Is coby made by a "master company"? (e.g. orion is made by emerson and their codes work for orion products)
Jun 23, 2007 | Coby DVD-224 DVD Player
Ilo dvd player/recorder
I think you are out of luck, unless you can find someone else who owns one, and will let you use their controller to program a learnable remote. I have purchased, and returned dozens of universal remotes...not one has worked.
Sep 23, 2006 | iLO DVD Recorder DVDR05
Televison & Video Logo
2,841 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
