SOURCE: i need driver for webcam farassoo
Driver download link at bottom of page:-
http://www.farassoo.com/product/webcam/fc-1440.htm
please rate accordingly
Hi Friend,
Kindly provide the model of ur webcam farasso or i will provide the link u can select the model and choose the driver for your use of free of cost
http://www.farassoo.com/driver.htm
Kindly check and revert back
Regards,
Ayyasam
Please be
informed that any Driver software depends upon the hardware make and Operating System.
So, you need to know all these information's to do get going.
Please find the Driver software's of your webcam
inside the installation disk provided with the System at the time of
purchase. In case if you do not posses the same then you
need to download the driver software from the web. As you have not mentioned
your Webcam make and Operating System you are using, I am unable to give you
the direct download link. However you can download the same by visiting the
website of the company that manufactured the Webcam.
Even here you need to be careful
to download the correct software for your PC. You need to be exact with the
Webcam Model number and the OS that you are using.
After you have downloaded the driver, to install just plug in the webcam on to
your PC and then Double click on the driver setup.exe file and go on clicking
'Next' until you get the 'Finish' option and restart the PC.
What I could recon from your question is that
your webcam driver is not installed in your PC.
Please be informed that
any Driver software depends upon the hardware make and Operating System. So, you
inside the installation disk provided with the System at the time of purchase. In
case if you do not posses the same then you need to download the
driver software from the web. As you have not mentioned your Webcam make and
Operating System you are using, I am unable to give you the direct download
link. However you can download the same by visiting the website of the company
Even here you need to be careful to download the
correct software for your PC. You need to be exact with the Webcam Model number
