Have lots of content in their like movies and such but cant be seen on the ps3 unless its in fat32 format, currently in ntfs.
You have to use 3rd party tool windows build in disk management only allows you format 32GB to fat32. No matter which way you use you'd better backup your files, and then there is a software could format NTFS to Fat32 without data loss: http://www.aomeitech.com/n2f/index.html
SOURCE: Formatting a Samsung MP0804H IDE extrernal HDD from NTFS to FAT32
Hi there Dave, well you can use a software called Partition Magic 8 to convert your 80GB hard disk to utilise FAT32. This software is quite user friendly. There are several options for you to choose form in this software including resizing your drive and creating partitions on the fly. However some settings requites a computer restart or reboot in order to complete successfully. This software can be obtained from most software stores or even download form the internet. After installing the software and running it, your drive should show inside the programme; right click on the drive you want to change a setting and select the options available. At the 'Format' button select FAT32. You will be asked for drive letters and cluster size but you can use the default settings, then apply the settings. Once you are done with that select the Okay button in the main programme window and the formatting process will start. Hope this helped you. Cheers :-)
SOURCE: reformatting an external hard drive
Id you have a xp disk when it loads it will ask you how do you want to set up the drive even though you have and external drive on your computer in the my computer icon Right click and open manage open disk management and you should see your usb drive right click on the drive and you should see format it has a dropdown menu check quick format and click ok and it will start to format the drive make sure you chose ntfs in the drop down menu .good luck
SOURCE: formatting hard drive to fat32
Xbox was not created to use external hard drives otherwise the software for it would be even bigger considering it is a gaming console. It might work if you use FAT but I can't say it for sure.
SOURCE: How do I format my Western Digital 1T to fat32 for ps3?
Without a firmware update your PS3 needs it to be fat32 as you've
noticed, and without the use of a utility Windows will not let you
format a 1tb using fat32
You're best be it to download a program called SwissKnife, it's a
utility that will allow you to format the drive the way you want
WARNING: Before using SwissKnife to format the drive, you have to take
all the data off of it (onto your computer or another drive), if you
don't then when you format the drive every file will be lost.
http://download.cnet.com/CompuApps-SwissKnife-V3/3000-2248_4-10070864.html
SOURCE: My HP Simple Save external hard drive worked fine,
Windows has stopped this device because it has reported problems. (Code 43).
Try reinstalling the driver software for your external drive.
Did you plug in a usb flash card? something that may have reassigned drive letters?
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
i have windows 7 and trying to get into fat32 not ntfs sorry if theres any confusion
