My cherokee wont start.. i run the key and it just run the crank b ut it wont start.. the check engine wont turn on.. if i wait a few minutes with the key on and after several minutes the relays in the hood clicks tiny and then faster.. then something with black tubes int the top of the engine clicks too.. and only when thos parts in the hood stop clicking the check engine light in the center turn on... and the gas pump turn on a few seconds and then if i run the key the engine starts runing.. when i stop the engine and wait a few minutes i have to wait again with the key in on position... any help?? no mechanic have repair it... please help
SOURCE: Starting Problem with 1994 Jeep Grand Cherokee
Assuming I understand your problem correctly, it sounds as if the car will only start once the check engine light comes on. The check engine light is controlled by the PCM (powertrain control module; or computer) which is also responsible for basically all engine operations including fuel delivery, ignition, emissions, and so on. If this light is not coming on, it means that the computer is not getting power. If the computer is not getting power then it won't start. The fact that you hear the relays click on when the light comes on is another indicator the the computer is not getting power as it also supplies power to the ASD (Automatic Shutdown Relay) which in turn supplies the power to the fuel and ignition systems. Check the ASD relay located in the power distribution center, if it is the same relay number as another un-important system, then swap it out to see if that helps. Make sure the plugs going into the computer are tight. The delay in the power going to the PCM sounds like a stuck relay, have someone tap the relays when the light is off to see if comes on. It is also possible that the PCM itself is failing.
SOURCE: 1994 Grand Cherokee Jeep wont start
It is likely one of your battery cables loose. Same thing just happened to me today. What you need to do is first lock the doors, and close them. Then you need to disconnect, and reconnect the battery cable, then if the security lights still blink you must use your key to unlock the door, then it should stop blinking, and start just fine.
SOURCE: jeep grand cherokee slow to start
THE THINGS YOU MENTIONED WON'T AFFECT CRANK SPEED. YOU'RE BATTERY IS PROBABLY ON THE WAY OUT THE DOOR. LOOK FOR CORROSION AND LEAKING BATTERYLIKE AROUND TERMINALS AND POSTS. BATTERY IS PROBABLY LOW ON CCA'S. NOW IF TALKING ABOUT WON'T START AND TAKES LONG CRANK TIMES IT CAN BE FUEL PUMP LOSING PRESSURE IN FUEL RAIL OR LACK OF FUEL PRESSURE CONSIDERING WHAT YOU MENTIONED. EVAP SOLENOID WILL USUALY SET A CHECK ENGINE LIGHT AND WONT AFFECT STARTING USUALLY UNLESS YOU HAVE A HUGE VACUUM LEAK
SOURCE: 2005 Jeep Grand Cherokee Limited, 5.7L V8, starter
Every morning at lunch time and evening my jeep won't start. It doesn't grind but the electrical goes crazy. After a couple of trys it finally starts. Help
SOURCE: 94 Jeep Grand Cherokee is hard to start. If I turn
Has any one soled this yet???????? Because I have the the same prob. but mine is only when it is could out blow 65 it will start but I have to keep my foot on the gas like a carb with no choke
