Checked spark plug, air filter. Any guidance would be much appreciated
SOURCE: Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
SOURCE: My 13 hp honda power washer has a miss when it's
Most likely fuel / plug. Easy to check. While running unloaded and miss-firing, try applying the choke just a little to increase fuel mixture (make run slightly rich), if clears may need carb kit. If it gets worse with slight choke running rich or plug faulty. Before you change parts try using premium fuel. If runs better problem solved.
