There are sensors in some car seats that pick up if someone is sitting in the seat, when the car is started, the safety system will check that if there is a person in the seat, if so, the seatbelt has to be clicked to stop the light from flashing. I have found that if I have a heavy weight sitting on my passenger seat, the warning light will come on to say the seat belt is not fastened as it thinks someone is sitting there. It could be a faulty switch under the seat that is causing your problem.
And the seat belt warning light and the check engine light are two different systems. The seat belt light means one of the seat belts is not fastened if someone is sitting in the seat, or the sensor for that seat has failed.
Probably no need to see an expensive mechanic. My seat belt warning light came on a few days ago when there were four people in the car and the rear seat belts weren't fastened (I thought that was why it lit up). However, the light came on and stayed on when I was the only person in the car. Logically, it suggested a bad connection somewhere, so I checked the connector under the passenger seat and made sure it was properly fastened together. I then sprayed a small amount of WD40 into the female clasps of both front seat belt connectors, clipped and unclipped the belts a few times and the light is now fine. Try it - it worked for my 2003 Escape.
Usually a sensor in the seat that recognizes a body in it. Check under the seat for any plug that may have disconnected. maybe someone kicked it with their foot.
