When i put paper A4 in feeder and hit green key it's work and read it A4 and print from cassette 1 when i put paper A3 in feeder and hit green key it's work and read it A3and print from cassette 4 the problem only with A4R in feeder ?????????? read it A3
SOURCE: size reduction from A3 to A4
put the A3 original on the glass.
press reduction button.
make sure you have A4 loaded into the drawer.
select that drawer.
off you go.
SOURCE: canon ir 2016 digital copier
you can have 1 of 2 problems.
the cassete paper are in A4 position ,or you can trie to clean the registry roller.
SOURCE: Canon PC 1060 will not SCAN
DO NOT USE ALCOHOL ON RUBBER ROLLERS! This will dry them out and cause more problems! Use a gentle cleaner like soap and water or Simple Green to clean rubber roller parts!
SOURCE: I m having Canon NP 6330 photocopier, my problem
i would look for paper behind the cassettes. being a service tech its very common
SOURCE: problem ir 5570
we have ir 5570,the problem is that it is not detecting papers in
cassette. i have paper filled in the cassette but nothing is show that paper is present
