Mike thanks alot. I found the problem was in pto safety switch. It wasn't makeing contact with the lever. thanks again grumpy!Mike thanks alot. I found the problem was in pto safety switch. It wasn't makeing contact with the lever. thanks again grumpy!
You can't post conmments that contain an email address.
jump starter with battery if starts look for bad ignition switch or battery dosnt have enough amps or bad contact in silinoid you have to buy one to find out
Sounds as though the battery is no good, unless you know otherwise & also had it tested Charging a battery doesn't address it's internal condition You have battery cables that corrode inside & can be voltage drop tested You have the starter & solenoid,ignition sw & such, to name a few,lots of possible causes & things to check
Check batry terminals are secure & free from corosion, check security of earth strap to engine & main power wire on starter, if ok have the batry load tested to ensure it can perform under load as the starter needs a lot of current. Have you tried a jump start?
you could just have dead cell in the battery which isn't getting enough amps to the starter,, have the battery LOAD checked,, that will tell you if the battery is actually good, just because it registers 12 volts isn't necessarily an indication that the required amps are present.
