I have a fridgidaire electric range F7 popped up while cooking. the door to oven locked and It will not disengage. food is still in oven and cannot get open. How do you manually disengage lock?
SOURCE: Fridgidaire Gallery Model#CFES387CFS6
tech17 posted the reply in december that worked for my oven w/same problem. hold in door button and pust cancel and it will reset after about 5 - 10 secs
SOURCE: frigidaire range
Unplug the unit, then manually depress and hold the light switch on the frame of the unit while plugging it back in. The lock should go back into the proper position.
Craig Mac
SOURCE: frigidaire CFEF372BC2 electric range - oven door
Hi .The oven door will not unlock until it cools down despite the cycle being finished.If it has not opened in a maximum of 1 or 2 hrs then oven sensor failed during self clean cycle and will have to be replaced.Try restarting self clean to unlock door .If not you will have to do the old coat hanger trick or manually move the lock mech. from rear,sensor cost $30-40.Hop this helps .Please rate my response :)
SOURCE: Frigidaire---oven door locks.
On my Frigidaire electric range with flat screen front controls, when the "Clean" control was accidentally pushed and the door locked, I could not unlock the door by cutting power, by running the clean mode for 30 seconds then pushing "Clear", or by hitting any button. What opened the door was holding down the "Clear" button for 30 seconds until the range started beeping and code "F11" read on the led. This worked. Good luck with yours.
SOURCE: how do I unlock the
Hello there:
This is a fairly common issue with ovens like these
You will need to unplug the oven from the wall or if it is hard wired find the breaker that feeds it and trip it now you will have to wait for 1 hour to allow the ovens internal reset feature to reset the oven controle panel now after is up AND NOT BEFORE plug in the oven AND YOU MAY HEAR A AUDIABLE BUZZ OR CLICK WITH IN ABOUT 5 MIN if so simply press the cancel button or if you have a reset button on it press it and now you will be able to resume what you were doing ok>
Hope this is very helpful for you
Best regards MIchael
