It only blinks and beeps -
I was embroidering and the wheel seemed tight
I oiled the bobbin area and worked the wheel.
but now even though I have a green light, the red light beeps and the machine will not start
any suggestions? in the middle of a Christmas project too...
Is the problem with embroidery only? If with both sewing and embroidery function and there is no error code (just 00) on the display, my wife experienced the same problem. There was an internal sensor that was bad. The sewing machine shop repaired with a new Singer part. Part was about $20, labor was $180.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
