Find a universal remote code
SOURCE: Code to program universal remote
You can select between tv, AV, dvd using the buttons on the front (second from the left I think)
SOURCE: Universal Remote
I downloaded the tv's manual, mine is a model:1350, but it says at the bottom of the manual it is from Memorex, so I found the codes in my remote(a OneforAll brand code 0463) and it worked. So if you haven't solved your issue, do a memorex code. Now that I look at the date you probably have. Oh well.
SOURCE: Parental Lock
I called the custoner service number 1-866-387-1902 & the parental lock code is 1369. I had the same problem and this worked for me. Good luck. This parental code is for all disney tv, dvd combos.
SOURCE: I have a 13
Tries the website 1-800-Remotes Factory Original.Get the same remote or exact remote to the original.
SOURCE: 13 inch tv, need to know which universal remote
depending on where you are in the world, argos if in uk, tandy if in the states, they do an all in one remote and all the codes are listed within the packaging.
