Question about Siemens SpeedStream 4200 (13A4200001) Bridge
Intermittent ADSL connection
I have an old SpeedStream 4200. It has worked perfectly up until now. Internet connection will be fine for a while and then just drop out for no reason. I notice that the DSL light flashes occasionally or goes off altogether. Can I assume than my router has just reached the end of its lifespan? I have recently reduced my home phone line rental plan....that wouldn't have anything to do with it...would it? Probably a stupid Q...I'm not tech savvy at all.
  • craigAM May 17, 2009
    i have same problem,, modem always wants to cut out.
    Scholar:
  • 99 Answers
The DSL light blinking or going out indicates that the DSL modem is loosing sync. This is usually caused by noise on the line. When you get the DSL service you should be given filters to put on all of your phones so that the phones will not interfere with the DSL signal. Those filters need to be attached to anything connected to the phone line that has the DSL on it except for the DSL modem. Other than that the problem could be on the service providers end, something outside your home, or the DSL modem going out. I would suggest that you verify everything is filtered, then contact your service provider so they can run test on your DSL line.
Posted on Jan 03, 2009
SOURCE:
Bridging a Motorola SBG900 to a Speedstream 4200
You can't use the Motorola SBG900 for that. The only way it might work is if the Motorola SBG900 had a 4-port Ethernet switch built into it.
Sep 16, 2017 | Arris SURFboard SBG900 Wireless Router...
Speedstream 4200
The ethernet light should not blink at all. The first thing to try is a new ethernet cable. If the problem still persists, then you need to check with your internet provider.
Storm608
Feb 04, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Static Ip with Speedstream 4200 Modem
I am assuming here with the way you have it set up your getting an internet connection.
what you saying i understsand mostly so i'll see if i can help you
first of all you have speedstreem modem that connects to you isp, this is assign your internet address from the isp if you paid for a static IP it would be in here, if not it's assiged by a dhcp from your isp company so if you if turn it off or have a power loss for anymore than 5-15min your ip changes.
now your modem then connects into your belkin router this as well as your modem it's prob set up as dhcp so it wants to issue each computer with an internal address of 192.168.0.X the reason for this is so it knows where to send the incomming information to what computer.
no matter what computer your using the address that goes over the internet will be the one assigned to modem from internet provider so if this need to be static IP to run your game server you will have contact your internet provider for an address.
but you may be confussing the issue a little, my suggestion to you would be:
1. go to your connections on each computer
2. right click on the lan connection choose properties
3. go to internet protocol (TCP/IP) then click properties
4. then click on obtain ip automatically and obtain dns automatically
this will remove the static windows address you may have put in.
try this and see if you can get you game or game server will work.
btw you may have to reboot your computers after this to get be sure to get the new address.
Oct 09, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Siemens Speedstream 4200 NetComm V300 on VOIP
When the V300 Line/Phone led flash in alternating fashion, it's telling you it's WAN connection is dead. The WAN light is off too. so internet and VoiP phone will not work
When the V300 Line/Phone led flash in sync, it can't register to the SIP server.
The V300 does not appear to be listed on the Mynetfone website though. Have you checked to see that your V300 has the latest Firmware. LINK
It may be that the V300 is not getting it's IP renewed. Can you alter the IP lease time? Do you have the V300 set up for PPPoE, or do you have it set to static or DHCP (refer CH4, page 25)
Jul 01, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Sleeping modem?
hmmm..sleeping modem disease..rare but there is an antidote...you may find that this is something that's in your network connections settings, and there fore, your modem is fine..check for any time out settings, in your network connections settings area. might be on advanced tab.
check your computers warranty here 4 FREE
Mar 22, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Belkin Router - Network works for 5 minutes than everything loses internet capability.
hi,
           This issue usally occurs when the router is able to save the data stored or in  other words the Router id not able to AUTHENTICATE,  but as you already got a new router and you have already done the fireware upgradation of the router. we can also upgrade the firmware of your speedstream modem.
plz do these following steps ,( plz disconect the router from the computer and modem completly while doing the steps )
The Efficient 5260 modems that can be upgraded are as follows:
Look on the label on the bottom of your modem. It should read:
SpeedStream 5260 Ethernet ADSL Modem
Part Number: 060-5660-00x (where x=any number)
Revision: any (all revisions seem to work)
If your part number reads anything else, your modem is most likely not upgradable.
For those curious, 5660 models 003 and earlier do NOT support G.Lite ADSL, only DMT. If you are buying a 5260 or 5660 model secondhand, and your DSL ISP uses G.Lite DSL, it would be a good idea to check with the person selling you the DSL modem.
UPDATE: As of 5660 Firmware v2.3.0(2) and later all 5660 including 5260/5660 hybrids support G.Lite ADSL. It pays to use the latest Firmware.
PLZ REPLY IF THIS HELPS, I WILL TRY TO FIND OUT THE RESOLUTION FOR THIS ISSUE
REGARDS.
Gunjan ';';';';';';';
Oct 18, 2007 | Belkin (F5D8231-4) Wireless Router...
Cant connect my router
what is the source of your connection thru telepon line or a broadband connection or DSL?i need to know this........
Jul 16, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
795 people viewed this question
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
