You can use hub for that matter. Use RJ-45 Cables (Crossover) for connecting just two computers and connect each unit with the cable inserted from your cpu to the hub. To create an RJ45 local area network in Windows, you will need: Several computers running Windows (computers running two different versions of Windows can be part of the same network);
Ethernet cards on a PCI or ISA port (with an RJ45 plug) or built into the motherboard. When applicable, make sure the diodes on the back of the network card light up when the computer is on and that a cable is plugged in.
