Dometic Rooftop RV Air Conditioner Logo
A
Anonymous Posted on Jan 20, 2018
How do i wire analog thermostat to digital
I purchased a replacement control box for my duo therm ac and the part they sent me was 3313189.000. It came with a digital thermostat but the new thermostat has only 3 wires and the old thermostat had 6 wires. There was no wiring diagram in the box. I need to know how to wire the new thermostat.
Michael Youngman
Level 2:
Sergeant:
  • Expert 296 Answers
  • Posted on Jan 20, 2018
Michael Youngman
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
180273
Points
743
You need to get a different thermostat.you can change an analog thermostat to digital, but you have to replace the motherboard with a digital compliant one. You can't just change the thermostat. Your best bet is to put back the old thermostat or upgrade to a different compatable thermostat
5 Related Answers
Anonymous
  • Posted on Aug 02, 2008
SOURCE: thermostat wiring for second ac unit
I replaced one unite with another and the wires are differance colors the old unites wires are red,purple,yellow,bleck and white the new one have orange,brown,cream,darkpurple,and white
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Aug 14, 2008
SOURCE: duo therm air conditionning/furnace thermostat in RV
Checked all breakers & fuses in panel ?
Anonymous
  • 534 Answers
  • Posted on Oct 30, 2009
SOURCE: We have a duo therm rv analog thermostat. When we
red wire to the r section of the thermostat white (heat) to the w marked on thermostat Green (fan) to the g marked on thermostat yellow (a/c compressor) to the y marked on thermostat. Blue to the c marked on thermostat. Orange to the orange marked on thermostat.
Anonymous
  • Posted on Aug 07, 2010
SOURCE: I purchase a 1997 Salem camper trailer and just
my ac works from about 8am til 10pm...after that the breaker trips and I can reset it but it will not stay on for more than 5 or 10 minutes...it doesn't matter if it's off until 3pm and I turn it on it still only works until about 10pm...if it is raining outside then it will trip several times during the day...at night we turn everything off...nothing is running except the ac and a fan...the fan runs all day also...
ZJLimited
ZJ Limited
  • 17989 Answers
  • Posted on Aug 18, 2011
SOURCE: have a duo therm
A schematic of the part number can be found here... Duo Thermostat Wiring.pdf
Additionally, go HERE for the Dometic Service Manual. See pages 39 and 40 as well as 50 and 51. Depending on which unit you have this gives the colors coding for the leads as well as the placement on the thermostat.
Hope this helps; keep us updated.
Duo therm ac in my rv quit when the converter burned up does the ac need 12v to work?
there is a fuse located under the shroud on the roof AC on a circuit board that controls the thermostat to turn on the power to the Air Conditioner replace it it is marked F-1 or, on some F-2 etc.
the air conditioner works on both DC voltage for the thermostat and AC voltage for the compressor
1helpful
Ac is blowing 3 amp 12 volt fuse in control box it is a duo-therm ac unit in an rv model #57915622
Pinched wire going to thermostat, condenser fan froze, or bad compressor
2answers
I purchase a 1997 Salem camper trailer and just replaced the Duo therm 13,000 Unit BTU. Everything was good until it was time to connect the wires from the thermostat unit to the analog thermostat on the...
Pay attention to wires from control box itself at the ceiling assy. Sometimes they will use a different color from control box, to thermostat. For example: Green coming out of control box, is attached to a blue running to thermostat, so you would attach that blue, to "G" (fan) on thermostat. Match thermostat colors to what is at the control box originally, not what color they used to run it to thermostat from there. Most try to match them, but others don't. What model Ac unit, and what model of thermostat do you have?
Have a duo therm ac and the low ac and low fan not work -
Thermostat on wall, or manual controls at AC? Did it work for you on low before now? Reason I ask, is that normally they are only a 2 speed fan ( low and high) so if it's a wall thermostat and has been changed from original, perhaps it the way the thermostat is wired.
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Duo Therm AC won't cut off with thermostat
Hi, sounds to me like the thermostat is at fault.You have done nothing wrong to it but cover it up. The t-stat is what controls it, turns it on and off. The only other thing that would keep it on all the time would be that the thermostat wiring could be touching together from the stat up to the unit. You might check that before replacing stat. I have seen this many times.You can start the unit and go up top and disconnect the stat wire and it should stop the unit.Then its either the wire or stat.Let me know what you find,
Sincerely,Shastalaker7
Thermostat wiring for second ac unit
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
