Hp Printer Error 49 is a communications error message. They can be tough to overcome since a few criminals actually make 49 mistakes. Often, these errors may be very brief errors that clear up with a reset or more permanent errors that need hardware repair.
HP Printer Error 49 on HP LaserJet printers is a connection error code that normally occurs when printing some document. It could be difficult to solve the problems if you have a few technological skills. You are expected to make use of HP Support Assistance in order to obtain advice from another qualified individual. It is the service provider tool that provides users with complete clarity of the HP printer issue. No matter what error code you're facing or what error codes you're getting on the computer, you're both going to get the desired response.
If you want an instant & expert-written solution check below.
Does it give a 49.FF95? As their is no such error code "FF95" for a HP 2420. However I've seen 49. XXXX error codes before (XXXX meaning weird Alphanumeric Characters and numbers). This type of error code you can try a couple of Items: 1st - Perform a Cold Reset: 1. Turn the printer off. 2. Hold down the SELECT button, and then turn the printer on. Continue holding down the SELECT button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds. 3. After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until COLD RESET is highlighted. 4. Press the SELECT button. The printer performs a cold reset and then continues its power-on sequence. 5. Check all I/O settings and reset any customer-set printer configuration values
If the machine still comes back to the Strange FF95 error I would start with the replacement of the formatter, Part Number for the Formatter: Network versions Q3955-60003 Non-network versions Q3953-60001
It would be nice to know what kind of printer this is. On HP printers a 49.xxxx is normally a critical firmware error. Could also be a bad DIMM or firmware DIMM. Try upgrading the firmware.
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
You need to get a technician in. The code is suggesting the formatter board.
Note that make sure that the technician (or you if you are replacing it) that once you replace the board and turn on the machine, don't do anything for about 10 minutes. No printing, nothing. Take out the network/usb cord out to prevent anyone from printing. The reason is that the NVRAM (memory) is updating the new board with your information. If anyone prints (whether from a computer or a configuration page) then it will interrupt the update and you will get the same error again.
