SOURCE: 1996 olds cutlass supreme won't crank
You can jump across the celonoid on the starter. If the engine turns over then your problem is either the celonoid or the starter switch.
SOURCE: 1006 olds cutlass supreme won't crank
try taking a power wire from the battery positive and getting it on the starter terminal and seeing if the starter turns over if it does it could be a fusible link that runs between the starter terminal and the relay
SOURCE: 1991 Nissan 240SX starter will not turn!
If you've applied 12VDC to the solenoid and it does nothing, not even click, then the solenoid is toast!
SOURCE: key switch on, push ignition button & nothing happens
Check your ground wire to the frame. Clean and refasten....and find a new mechanic, no excuse for inferior workmanship...Sure sound like a ground problem !......Good Luck to you friend....Tim
