Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
Lost power now only electric burners wook - Frigidaire Gallery GLEFM397DS Electric Kitchen Range
  • Official Brand Answer
  • 4,342 Answers
Sounds like either the elements are bad, or the communication to the elements from the control board is now compromised.
Posted on Sep 04, 2012
6ya staff
SOURCE:
Ps3 i have lost my account the net work account when i got the ps3 wooking tryed to got ps network it said i had make a new account lost the new maps how can i get my old account back thanks kev
Well if you remember the info username and password make a new user sign up for psn network then click use existing acc and enter it in otherwise you can call sony and they will ask a few questions to you to prove the acc is yours and they will imeaditly fix the prob and get you the maps :)
Apr 17, 2011 | Sony Playstation 3 (PS3) Console
My roper dryer will not dry all the clothes in one cycle.
try runing your dryer with out the vent hose.if your dryer wooks well than you have a problem from were the vent hose hooks up to your dryer and the outside vent.
Nov 17, 2009 | Roper REX4634KQ Electric Dryer
No electrical power to ovens and control panel.
It appears that you have lost one half of your power. That is you no longer have 220 volts but do have 110, enouch to power the electronic ignition. I would check the circuit breaker first to see if it is sending power on both hot wires or just one.
Jul 17, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Sep 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Jenn-Air electric stove top - burners/fan won't come on
you may have lost a leg of your 240V service. make sure you have 240 to the appliance and then start chasing down where you lost it. there is no onboard trip or reset on this unit
Apr 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JES9860 burners and oven stopped working problem with display
sounds like you lost power to your stove. if you can't reset the clock, it needs to be replaced. in otherwords, the power outtage shorted out the clock.
have a technician replace it.
Jan 14, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Whirlpool supercapacity 465 range won't heat up
hoops, it almost sounds like you lost a leg of power, L2. L1 is sending power to the board but but it's not making the loop. Too much of a coencidence that the burners and oven are not working. Check the cord connection to the oven. You should have 220V across the 2 outer terminals. 120V from each end to center terminal. Let me know what you find. Catriver.
Dec 16, 2007 | Whirlpool GR465LXLS Electric Kitchen Range
No power to clock or oven with the door closed
it sounds like the oven lost its neutral feed. I would check where the cord goes on for a good connection at the middle terminal(white) if not there it may be lost elsewhere Dont forget to rate my solution as solved if i answered you question accurately....Thanks!!!
Sep 30, 2007 | Whirlpool RBS245PDS Electric Single Oven
Jenn-Air Electric stovetop / oven range SCE4340B - Fuse blown ? ? ?
Andy, sounds like you lost a leg of power. Check the breaker box first. Maybe the contractors tapped an existing breaker instead of adding one for the burner/broiler. You would have to check the terminal block on the range. Should read 120V from each end to center and 220V across the two outer terminals. If you don't have this, something got messed up with the contractors. Catriver..post back
Mar 04, 2007 | Jenn-Air JED8430 Electric Cooktop
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
54 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
