Lokking an unlocking code for Nokia N70 IEMI 357093006264794, please help. Thank you x
HI visit Unlocking4u.com to unlock your Nokia N70 mobile from network lock .Here they ask you the network name to which your mobile is locked and the imei number of your mobile .Finally they send you code to unlock your mobile.
SOURCE: HOW TO FORMAT THE NOKIA N70 MUSIC EDITION PHONE
hello my dear
i m praveen kumar owner of pintu telecom.
u want to formet ur n-70.
then try this
step 1 : switch off ur mobile
step 2 : press call buton+star(*)+three(3)
step 3 : then switch on ur mobile
after this wiat for some time then ur mobile will format.
ok
if ur satisfied then contect me on g-talk my id is prave03
or mail me on [email protected]
SOURCE: 6500 slide on3g unlocking codes to 02 network
Dude, I have no clue what you are talking about. But did you try the last 4 digits of your phone number or maybe the BHLPJ code?
SOURCE: nokia 6500 slide
YOU CAN GET A BB5 TURBO SIM, ITS A PIECE OF PLASTIC WHICH HELPS BY-PASS THE SIM LOCK PROTECTION COMPLETELY CHECK OUT THIS LINK MATE :
http://cgi.ebay.co.uk/BB5-TURBO-SIM-CARD-UNLOCK-NOKIA-E65-N73-N95-6300-6500_W0QQitemZ110292003241QQcmdZViewItem?hash=item110292003241&_trkparms=72%3A12|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
SOURCE: nokia 5310 security code unlock
Check this
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart.
Increase battery life by 30% because phone receives less signal from
network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol
up(arrow keys) for 3 seconds, should say pin code. Press C,then press *
message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user
groups) to 00000 and ure phone will sound the message tone when you are
near a radar speed trap. Setting it to 500 will cause your phone 2 set
off security alarms at shop exits, gr8 for practical jokes! (works with
some of the Nokia phones.) Press and hold "0" on the main screen to
open wap browser.
Thanks.
