I think it must be the water got inside the electric plug at the bottom of the kettle where it normally sets on the base as I tried to clean the lime scale...
So basically whenever I turn on the kettle the whole power at home will be turned off because of this kettle. It's rather new, can anyone help by telling how can I fix it myself.... Great thanks!
It depends on how long you switched on. *check to make sure that the switch is transmitting electricity if not... *from my experience with kettles you will need a new element*Depending on the kind of kettle you are using check the power cable and the base of the kettle to make that there is contact between the kettle and the power cable.
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle. Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
I think you would only solve this problem by cleaning the thermostat contacts, or replacing the thermostat which wouldn't be worthwhile as it's likely to be cheaper to buy a new kettle. Besides this , just getting into the kettle needs special 3 tongue screwdriver and then a certain technique to open it up without damaging the plastic parts. Im'e afraid its a throw-away world now and its not good .
Looks like it is damp on the inside where the electrics are. Discontinue use immediately. You could try to open up the bottom and dry it out, but some do not allow access. So, in that case, a new kettle is in order.
Check the obvious, 13amp fuse, if intact connect a multimeter switched to ohms across the live and nuetral pins of the plug (not plugged into mains) the reading should be between 0.05 ohms and 1.5 ohms if higher the element has burnned out or the over temperature sensor has activated. to determine which you will need to open up the bottom of the kettle and expose the wiring. using the above multimeter with the same settings locate the heating element this will have two terminals protruding from the water compartment thes will have eithe screw or spade connections, connect the multimeter across these two terminals and check for the readings above if correct the problem is the over temperature sensor if not then the problem is the heating element. the over temperature sensor will be a circular disk with two terminals clamped to the underside of the water compartment.
Probably the wires inside melted together and now as shor circuit occurs it causes the fuse to blow. remove the bottom of the kettle and check the wiring. There's no rocket science, so you'll identify the problem after visual inspection.
Some switches are called momentary and others are the click on and click off type. It could be a problem with the switch if is is the click on type. It could be a relay that "seals in" when you press the on off switch to on. By "seal in" I mean, the kettle is wired so that when the relay coil energizes, it closes a contact when it is electrified and becomes an electric magnet and the energy that was going through the on off button, is now going through the closed contact on the relay. If you don't here a clicking sound like you used to, it could be a fuse inside inside of the electrical box on or by the kettle. I don't know by the information, if this is a household small appliance or commercial? Even if household, it should have the same basic setup.
This may be of some help to you
What About The Kettle?
Despite being metal the kettle is cool touch (a tough special grade plastic interior). A good safety feature is that the kettle will only switch on when the lid is closed, there is a special lid release button. The kettle also has automatic overheat protection. Of course the kettle is cordless and has cord storage in its base. Water quality? Well, it's better if you use filtered water, but with this kettle it is even better - it has a removable stainless steel limescale filter in the spout!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
