I have a sharp tv.. i accidently changed the channel with the regular sharp remote .. now i cant seem to find the channel so dish can link
Meshell Coles,
I would be happy to help get this fixed! If the TV is connected via a Coax cable, try changing it to 3 or 4 if TV1. If it is TV2 try 60 or 73. If the receiver is connected via a RCA (Red, Yellow, White) cable, HDMI cable, or Component (YPbPr), make sure the receiver is on the correct input.
If you have any other questions, just let me know!
Tommy Faust
DISH Social Media Representative
SOURCE: cant find code for emerson lc320emx toprogram to dish remote
Try 1465. However, you will still have to use your other remote to turn the unit on. :(
SOURCE: REMOTE CONTROL
If you're lucky it will respond to code 10178, if not then you will need a rc64 directv remote and try the proview codes. The proview codes are worthless in any other directv remote other then the rc64 series.
SOURCE: px-rc1 remote lost code book
I have a PX-RC1 from XS Cargo (universal remote) try this link, this should help you. http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
SOURCE: dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
