On a Mercedes Benz the flasher relays are in the fuse box in the engine compartment. it should be a coloured square block that you can remove by pulling out.
The location of the flasher relay switch on your vehicle can vary depending on the make and model. Here are some general steps you can follow to locate the flasher relay switch:
Check the owner's manual: The owner's manual may have information about the location of the flasher relay switch. Look for a section on fuses or electrical systems.
Check the fuse box: Some vehicles have the flasher relay switch located in or near the fuse box. Check the fuse box diagram to see if the flasher relay switch is listed.
Look under the dashboard: The flasher relay switch is often located under the dashboard on the driver's side. Check behind the steering column or near the fuse box.
Check under the hood: Some vehicles have the flasher relay switch located in the engine compartment. Look for a black plastic box with relays and fuses inside.
Use a wiring diagram: If you have access to a wiring diagram for your vehicle, it may show the location of the flasher relay switch.
If you are still unable to locate the flasher relay switch, consult a repair manual or seek the assistance of a qualified mechanic.
if you google Where is flasher relay located on 1999 Chevrolet Silverado 1500 you will find answers. Look above the fuse box under the left side of the dash to locate the flasher unit. The flasher is a square unit that looks like a relay. It will have its own receptacle mounted separately from the fuse box.
? 5:35
https://www.youtube.com/watch?v=ikJHh7OLcXg
Aug 16, 2009 - Uploaded by bguess
HOW TO REPLACE THE TURN SIGNAL FLASHER ON A 02 .....Replacing flasher/turn signal relay on a ...
Your Olds has 2 flasher relays. One for the turn signals and one for the hazard lights.
The turn signal flasher relay is located on the driver's side, under the dash, mounted on the steering column.
The hazard flasher relay is located driver's side, under dash, driver's side of steering column, mounted on fuse panel.
it's basically a stand alone relay... most times... look for a relay by itself and often round. my ford winstars flasher relay was actually located in the fuse box under the drivers side dash. it was blue and larger then the other relays so that may be a clue to you.
