Serial number 11912656
SOURCE: Match the year of my Rolex Explorer 1 from the serial number
I would expect Rolex to have a record of all their watches and if you contact your nearest dealer, they should be able to help you.
You can find a store guide on their web site "rolex.com"
SOURCE: Finding serial number of a Suunto Vector Watch
mcdevito75 here, Contact the Suunto Company useing the contact info supplied in the box the watch came in.
SOURCE: Is my watch authentic?
no need for serial number- look on the dial, if the 'x' marking the ten o'clock has 'cartier' written on it, your watch should most definately be authentic.
SOURCE: opening an elgin pocket watch
The best tool to do it is watchmakers knife, but any proper knife with hardened steel blade can do the job. Make sure the blade is NOT flexible.
Check carefully the sides of your watch and you will notice the groove. Place knife blade into that groove and press it in. At the same time try to make a scooping turn to lift the caseback. Usually there must be underlayed caseback as well and it opens exactly in the same manner.
Make sure you do all this carefully and do not let the blade to slip or your watch will end up with nasty scratches or even damaged movement.
That job isn't a big deal, but requires some skill, so, BE CAREFULL.
Don't forget to rate, please.
SOURCE: on a rolex watch, does it have to have the serial
Numbers on case back are inside. Number on case is outside, located between lugs. You need to remove bracelet to see it. Rate me, plz.
