My abdorer twister - body analyzing scale has switched to kg. i want to switch it back to lbs. i put a new battery in it, pushed the set &up arrow at the same time to move to the proper user, set the user/female/age, but it still won't let me switch to lbs. pleaswe telll me how.
I updated this review 3 weeks after getting the original one -- I contacted the company to see if I was doing anything wrong to get the body measurements. After telling them what I had done -- they determined that perhaps the scale was defective. They sent me a brand new scale and I did not have to send back the original defective one. The weight is consistent and doesn't vary when you move it to different spots. I love this scale and it looks very sleek too. After I figured it out, set up was simple and it literally took me 5 minutes to set it up
INTEY Body Fat Scale Body Composition Monitor Measure Body Weight Fat BMI...
SOURCE: Scales show weight in kg. How to get them to show lbs.
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
SOURCE: Need to reset a set of avon curves body weight
You cannot clear out the memory but you can overwrite each Person. I could not find instructions online anywhere, so I looked at Weight Watchers scales and found a sililar one, downloaded the .pdf instructions and followed them on my Curves four button scale.
Click here for those instuctions
http://www.conair.com/instruction_booklets/07AD15010%20WW31%20IB.pdf
SOURCE: Tanita Ultimate Scale 2001 - no user manual -how to set it?
does your scale have an orange SET button and a button with a triangle (or arrow) below the display?
Try this... make sure the scale is turned off. (and you are not standing on it)
Now press the SET button.
2 arrows should appear on the display. use the arrow/triangle key below the display to make changes and the SET key to choose.
If you have the same scale as me, you are prompted to chose Adult/Child followed by Male/Female, and finally input your height in feet/inches by pushing the arrow/triangle key until the display shows the desired height.
Press SET to finish and step on the scale like you usually do. It will now show your weight followed by your body fat %.
Hope this helps you!
Jacob
SOURCE: Changing user settings on Conair WW67T scale
1. Tap the scale
2. Wait for "0.0" display
3. Set
4. Use the up arrow then stop on the user you desire
5. Set
6 Using the up/down keys enter Height
7 Set
8 Using the up/down keys enter Age
9 Set
10 pick the little man or woman
11. Press
SET - the scales will redisplay your profile settings for verification.
12. Wait Until
the Display Goes Blank.
13. Tap the
Scale.
14. Press
USER, select desired profile, P-01 is the default.
15. Wait for "0.0" display
16. Step
onto the scales and wait for all measurements to display
SOURCE: How do you switch the unit of measurment from kg
When you first turn the scale on and you see all the units of measure across the top of the display, keep hitting the "on" button until the unit of measure you want is displayed.
