The manuel that comes with the Juki 1541-S is for people familiar with Industrial Machines. I need a manuel I can easily follow instructions step by step.. this is so totally different than the regular machines. Please help.. Thank You Patti
SOURCE: Threading a consew RB-1 sewing machine
Send an email to me at [email protected] and maybe I can help. I'd need more info. on your ploblem. I'll start you off with these two things assuming that your difficulty is with the bobbin as you state "underneath & threading". Notice the white painted dot on the the machine arm at the drive pully. Notice the white dot on the pully. Allign these two. Tilt the entire machine head back so that it is resting on the word verticle finger stop (or get underneath the machine). Bobbins are loaded by pulling the small chrome lever w/ your thumb & index finger (this is an unlocking latch). Do so moving it outward to about 90 degrees. Usually while you do this the holder and bobbin just pop out. To install u just snap then on. It's placed when u hear a click. For more info email me directly. Doug
SOURCE: I have a Euro-Pro 9160 computerized sewing
Yes,
Go buy a can of canned air from a computer store and blow out your bobbin case area and any other lint you see.
Then place a drop of of on the needle bar (right above the screw that holds the needle in) and one drop where the hook (silver part) goes around the bobbin case (black part that holds the bobbin case) (see picture)
-Chris
SOURCE: how do you reset the
HI THERE
CONCERN HOW TO RESET. THERE ARE MANY TYPE FOR CONTROL BOX WITH THAT MODEL.
1-SC500/510 CONTROL ( PRESS -- key and + key and down arrow key and power ON , it will appear rs on panel ) control back to factory set.
2-SC810/sc910N control ( press -- key and + key and left arrow key with power ON , it will appera rs on panel) control back to factory set.
if need any information please ask or mail me ( [email protected] )
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
